Hoping for an easy solution that doesn't involve a cable replacement. Shifting is difficult into forward, neutral, and reverse. Hoping throttle replacement and cable lube will solve. Any similar experiences?
detach the cable from the transmission linkage and manually try moving the linkage to see if there is any resistance. That will confirm whether the problem is in the cable.
