393 HEAD DISCHARGES
BILL TRIPP
On page 42 of the Beneteau loose leaf book is a Y valve. Where does the C-discharge go and where does the B-discharge go?
Stan
Y Valve
I own a 361 but I believe the Y-valve configuration is the same. One side goes into your holding tank and the other side goes to the thru hull for direct discharge. If you have a macerator pump you would likely, although not necessariy, have a second Y valve
