38 engine noise
Jun 9, 2014
4
Catalina 38 Tiburon
While under sail we are experiencing noise that almost sounds like the engine is still running. Upon further investigation it appears that the prop shaft may be spinning, this occurs both in neutral and forward gears with the engine off and seems to stop when put in reverse. Any help or ideas would be greatly appreciated.
Oday 35 and Mariner 2+2 Alexandria, VA
First, don't worry, then just sail in reverse. Many props will spin when left in neutral or forward. Putting it in reverse after shutdown has the effect of locking the shaft. A spinning prop can cause quite a bit of drag and noise/vibration, but in neutral, it should not cause any harm. Some owners manuals recommend neutral or reverse, but we have always locked ours in reverse. Just be sure to put it in neutral before starting the engine.
Jan 4, 2006
6,520
You Should Find Out ....................
...................... the make of your transmission before deciding where to leave it when under sail.
The attached may not apply to your set up but it shows the problems that can arise from not knowing which gear to leave it in.
If you do a search here on "transmission position" you will read for years! This is a recurring question.
Yanmar engines - read what Ralph posted
Universal engines with Hurth transmissions - reverse or neutral, never forward.
Nov 22, 2011
1,193
Ericson 26-2 San Pedro, CA
MaineSail did an experiment in which he showed the freewheeling prop as having less drag than when fixed--at least under the configuration in which he did the test.
Claygr
Feb 10, 2014
75
Catalina 387 Milwaukee, WI
Note that the Yanmar advisory only applies if you have a fixed prop. If you have a folding prop, the transmission needs to be in reverse for the blades to close and then it can be moved to neutral (or left in reverse).
