37c Table
24
Hunter 356 Deale MD
The table in our 37c is wrapped around the mast. From the factory specs it looks like this is the original layout. The problem is that when the sides are down it still takes up a lot of room. Has anyone modified the table so that it is a fold up or stows out of the way? Frank sv *Stargazer
W
Walt Golembewski
Mod to 37c table
Hi, I've modified my folding table, but not because it takes up too much room -- I've gotten used to it as it is. However, I've modified it so that I can remove it whenever I want to, which means that it's now a lot easier to step the mast and get access to the bilge areas. But I do move the table to the stbd side of the cabin when I need a bit more floor space, so this approach might work for you. My mod was to relocate the forward-most table leg so that it is just aft (instead of just forward) of the mast, and then to carefully cut out the top center section of the table. When cutting the top segment of the table out, I cut from the widest section of mast hole out in an athwartships direction about 1/4 inch, and from these small cuts made two parallel cuts forward to the end of the table (about 10 inches). That whole piece lifts out. I fabricated and epoxied a piece of hardwood about 1x2x12 to the underside of the table to strengthen it where I cut. This hardwood piece juts into the cutout the 1/4 inch I mentioned earlier, so it serves also to support the cutout piece, which now slips in an out whenever I want to move the table. Vertical grooves I routed in the support pieces accept a small piece of hardwood that I glued on to the bottom of the cutout piece, so everyting stays in place once installed. I also had to modify the supports for the table leafs as well, but now the table can be removed anytime I want to or need to. It is a bit difficult to describe in words the details of what I've done, but if you're interested I'll try to take some digital photos or diagrams and e-mail them to you if you get back to me. This was a wintertime project for me last year and works well. The table is still very stable, and one has to look closely to see the removable piece forward of the mast, as I used a very thin saw blade to do the cutting.
Ron
Ask Gene
Gene Gruender of "Rainbow Chaser," has done the Mod you are looking for. He has a lot of bluewater experiance in his H37C and has done many really good mods. In this case he has completely re-done the table so it folds up against the wall and opens all of that needed floor space. At one time there were some photos here at HOW. You might be able to find them. Ron
Ron
Gene's website has changed. Here it is..
Here is Gene's website. He has pictures and discriptions of everything. Once you get to the site, click on Boat mods and get ready for some eye openers as well as floor openers. Have fun and send Gene a thank you note... Ron http://www.geocities.com/TheTropics/Cabana/7414/index.html
