37c Rudder Quadrant
Oct 2, 2019
6
Hunter 37 Cutter Philadelphia
Could anyone get me a few photos of how your rudder quadrant attaches to your Rudder shaft? I had problems with it slipping this summer and jury rigged it and am now trying to fix it right.
thank you!
Sep 29, 2016
74
Lord Nelson Lord Nelson 35 3 Full time cruiser
I can't post a picture for you because mine is currently disassembled, but it's really just a circle cut in half that's placed around the shaft. There are bolts on the outer edge that clamp the quadrant together and then a bolt through the center that goes through the shaft. If yours is slipping the center bolt may be sheared.
Oct 2, 2019
6
I wonder if I have a different quadrant, the bolt through the shaft does not line up with the quadrant and seems to need some type of key to connect to the quadrant.
