37C prop size
Oct 18, 2019
4
Hunter 37 cutter St. Joseph
I have recently purchased a 1979 37 Cutter. I was wondering what the proper prop size is for the boat and max prop diameter.
Thanks
tom
Tom... You ask for the "MAX SIZE" based upon a boat brand and length. While there are generic sizes, it is impossible to know the "Exact Max Size" on your boat because we can not see if a previous owner attached anything to the boat bottom (i.e. depth sounder) that might affect the answer. It is best that you check your boat for max size by actual measurement, noting some distance is needed from the hull to avoid cavitation. Your prop source can likely help you with this issue if you can give them a photo of your hull bottom and the distance from the shaft to the hull bottom and distance of the end of shaft to the rudder or skeg if appropriate.
Measurement is easy if the boat is on the hard. If in the water you can use a diver to get the measurements for you.
And I would like to welcome you to the forum.
Johnb
Hunter 37-cutter Richmond CA
Suggest you post in the Cherubini forum.
Also I have inherited the HC 37 owners list from Jim Legere so if you want a copy and/or wish to be added please private message me
John Brecher
