Archives
Everyone complains about the difficulty in raising the 376 main. Lubrication etc does not help. I now have a block on the headboard with a 2:1 halyard of 10mm line - double the length! Means attaching the bitter end to the masthead. Fortunately there is a suitable hole in the crane to take a 1/4" shackle.Suggest you also look in the archives.Jim,Suggest you DO NOT ease the topping lift as it is important to take the weight of the boom off the sail whilst hoisting. I top mine up high after lowering and then it is ready for the next hoist.Also most people find their topping lift frays through inside the mast at the top. The last foot MUST be cut off at least once a year. I am thinking of having a length of wire at this point with a wire to rope splice to the fall.Regards,
