Mike D. ...Not so easy...
Mike,To add the inboard track near the companionway would not work, even if you could through bolt it. Once a theoretical sail extends past the shrouds and chainplate you can't sheet it in that far. the abgle you pull to get back to the car on the track is so severe the car would jam. Also the curve that put in the rearmost part of the sail would prohibit good performance. I did think up a solution... here goes folks so far this only owrks in my brain....which many say doesn't work that well to begin with.Get a 135 to 150 genny and shet it to the turning blocks mounted on the aft rails as described earlier. Lead these to coaming winches, or to the coachroof winches and loose alittle seating room on that side of the boat. Now go up to the coachroof and mount a hefty u-bolt near the solar charger, and make sure it's through bolted. Now use a spinnaker pole attached to the ubolt and the sail. Having the pole rearward of the mast allows it to keep the rearmost past of the sail open to give you power without interferring with the shrouds or chainplate. This would allow you to control sail shape, and have fair leads to the snatch blocks and winches. Ah it works here in my squash, maybe I'll give it a try!I should've put a warning on this that read.. Caution, reading this may make you dizzy, and recovery may not be complete without getting thoroughly intoxicated. If it still makes sense then maybe we're on to something.Bob KnottH380
