376/380 water leaks in forward cabin
Derek Ten
Do any of you 376/380 owners experincing water leaks in the forward cabin? DT
Russell
Check to anchor drain
We experienced some water in the v-berth when we were in heavy seas and the anchor pulpit drain was clogged. Lots of water over the bow, and a slow drain allowed water into the rode compartment/v-berth. Blow out the drain whenever you fill the water tank and it should be ok. (or avoid water over the bow, but what fun is that) Russell s/v Allie Kat
Darcy Peck
Leaks
We had water leaks in the v-berth of our 340. One source was the sending unit fitting on the top of our water tank leaking & flooding the v-berth sole. The other source was the sides of the anchor locker. The sides had been cut out at the factory, opening a void allowing water to enter the v-berth draining down under the cushions. It took us quite awhile to find the problem. We finally removed the fwd trim piece in the v-berth exposing the anchor locker 7 we could see the water entering while we used a water hose. Check under the sides of your anchor locker with a mirror for any similar openings. Solved our problems.
F
fred fuller
leaky windows
my lewmar windows were leaking. they leak behind the liner so it is hard to see where it is coming from. i tightened them and they seemed to stop. before launch i will take them out and re-bed. just pull the plastic moulding off and tighten the screws.
