37 Cutter feedback
As to the sails, a good sailmaker can measure and probably come up with much better sails than the originals. If he knows your intended usage, he should be able to give you a much better setup.This boat has a lot of weather helm. I added a bowsprit and moved the forestay out about 3 1/2 feet. It helped a lot. If you are into big projects, you might consider this also. Decide before you order your sails.Moving the boom up - Yes, I moved mine up, about 6" and I will move it another 6" or so soon as it still scrapes the top of my bimini. The main thing you need to watch for is whether you have enough room to raise the mainsail that much. You might find, if you don't have the clearance at the top of the mast to raise the sail farther, you just created another project.Standing rigging - the original stays are 9/32". I would recommend going up one size if you're going to replace them. Some will say that the rigging size is not that big of a deal, but I sleep better now.Not asked, but about the chainplates: I've now found 4 cracked chainplates. The way they are installed, the rigging doesn't pull straight in line, it outs a side load on them. The cracks I've found are all on the outside of the top bolt hole, which leads me to believe that they aren't heavy enough.I've replaced 2, and am in the process of replacing the rest with 3/8" in place of the original 1/4" plates. These can be made at home, they are just 3/8" by 18" bu 1 1/2" stainless stock. Drill the holes, grind the curve at the top, polish and you have new ones. If you're not up to that, I had my first 2 made at a machine shop for $40 each, material included. I strongly recommend any H37 C owner check theirs.Most of the upgrades, etc. we've done to Rainbow Chaser are on a website. The link is here on the Hunter Owner's site or just go to:http://www.geocities.com/thetropics/cabana/7414Gene GruenderRainbow Chaser
