big job, maybe worth it
As Ed mentioned, I tore mine out and started over.There is really plenty of insulation on the sides and bottom of the original one. The problems with the original one are:1. The top is just plywood.2. It's not shaped very well to be used3. Access is difficult.The place where the drawers are is pretty much wasted. Mine box is now next to the engine, where the drawers used to be, and the outer area next to the hull is storage.I mocked up the shape of the area I had to work with in my garage, then made a box that would still leave me plenty of insulation on all sides (6") and 4" on top. If you do this, you have to either construct the new box inside the boat, or take care that it will fit through the companionway. (Seems basic, but I've overlooked basic things before!)After suspending the bos where it was to go I layered up blue styrofoam insulation board around it, filling voids with a spray can of foam insulation and presto, a new box.It's not advertised, but you can get your evaporator from Adlar flat, or custom bent in addition to the horizontal and vertical box shapes. I strongly recommend you get the larger sized evaporator, and suggest you consider getting it bent to fit your finished box so that you make better use of the space. When I got mine, it was a $50 surcharge to have it custom bent. I've talked to people who got them flat and bent them themselves, but I don't recomend it.Also, the supercold machine has no more cooling capacity than the cold machine, it just has a bit better corrosion protection, and it has the capacity of adding water cooling. The best choice for performance and cost is the coldmachine compressor and the larger evaproator. Consider mounting it where it can draw in cool cabin air instead of air from a small compartment, or re-circulating the engine air. Mine draws air from above the galley counter, and discharges it into the engine room. Do not consider the holding plate option, it's not for our type use. If you have questions, give Adlar a call, they will tell you what is what.It was one of the more useful mods we made to Rainbow Chaser, but as Ed also says, it is a lot of work.
