361 cutlass bearing
102
Beneteau 361 Quebec
I have to replace my cutlass bearing and I would like to find out if there a place to get a cutlass bearing for my Beneeteau 361, year 32000, at a better price then the one from Beneteau? Thanks for your input.
Georges
Jun 7, 2011
83
Beneteau Oceanis 361 Marmong Cove, Australia
suttonski
George
Have Beneteau given you a price for the replacement bearing...?
I am assuming your not happy with the price given and am sure that you will find a cheaper supplier for your cutlass bearing, I would try your nearest bearing supplier, that is if you have all ready removed the old one as for a match.
Let the forum know of your outcome.
Cheers Ben
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
The price from Beneteau isn't that bad, $61. It's the same cutlass as on mine.
Feb 26, 2007
102
Beneteau 361 Quebec
Yes, that is the price I got. I thought it might be cheaper but I will probably go for the Beneteau one. I have not removed my cutlass bearing yet because I could not get the propeller to slide out. I think I will need a puller.
Thanks
Georges
