340 just beat a C&C 40 last weekend in our regatta
I would agree if you think the 340 is lacking in racing, then it needs tuning badly.I've added a feathering prop and made put full battens in my sail. Although I've adjusted the shrouds and forestay so they are tight!!!, a pro could probably do better.So far I've beaten everything in sight except for the 40 C&C and last weekend I added that to my prizes <grin>.Of course I had quite a few years racing a Hobie 18 back in the early 80s which helped positioning, stealing air, rounding marks, etc., as well as having the same skipper and/or crew (depending on whose talking) for 20 years. But then you probably have, too. Since you asked, the winds were less than 10 mph, had a cruising spinnaker wing on wing with the main as much as possible, as well as knowing that I could beat him in such winds. Attitude wins more races than anything else <grin>.ps: I also check to make sure that the feathering prop is in the vertical (less drag than horizontal) position. Little things mean alot.
