Count my vote for the 33.5.
I like the more "traditional" 33.5. The sail plan, rigging, deck layout, and interior configuration all seem to be more adaptable, flexible and "seaworthy". (Can I say that since I sail primarily on a lake?) I like the wider side decks for moving forward to manage the head sail or gybe a spinnaker. While main sail controls further aft on the boom can be a plus, the pedestal mounted traveler on the early 336's just doesn't provide the needed control. The cabintop mounted traveler and mainsail controls on the 33.5, though mid-boom, provide more utility. Neither cockpit is great for racing but the 33.5 is better. The "hot tub" design on the 336 is probably great at dockside or on a light/moderate day, but in a blow, the more traditional design will be more comfortable. The big, full-battened, roachy mains on the newer Hunter models seem hard to conntrol as well as difficult to raise. I see a few 29.5 sailors who are accomplished at the art of twisting the sail to spill off enough wind to stave off reefing in what most of us consider moderate conditions. The 33.5 sailplan will indeed be similar to your '93 Hunter 30. You will be way up on the learning curve when it comes to knowing what to do to make the boat go, under control. Consider spending savings from purchase on upgrading: 1. Sails if older boat2. The mainsail traveler car to gain additional purchase.3. Mainsail blocks to Harken or Lewmar for less friction and more power. 4. Feathering prop. 5. Air Conditioning in your part of the country. 6. ST 40's for primary winches, exp. if you use a larger headsail and/or race. Or, buy a 35.5 or a 37.5 pre 1996. I admit that Hunter has lost me as a prospect for "new" gelcoat. Good Luck! rb
