James
The FRP support floor/pan directly below my compression post base has fallen 1/2" +/-causing the sole to also bend down twards the center a bit. There seems to be some kind of fiberglass bedding caulk below the pan where it sits on the main hull cross supports. I believe it may have been that way since it was built (I am the third owner). Has anyone else had this base/pan/sole sagging situation? I can raise the sole a bit with no problem although I need to know if this is a serious structural issue. Please advise. Thanks.
