321 bilge pump access
3
Morgan 321 Olcott NY
I need to get at the electric bilge pump. It is under the cockpit aft of the engine out of reach. There is a narrow cutout in the quarter birth and another small one in the port cockpit hatch, neither are big enough for me to get in through.
Jun 9, 2008
1,853
- -- -Bayfield
Sounds like they built the boat around the pump. Can you cut out a bigger access hole? How far away is the reach? Can you get a smaller person in to do the job?
Dec 27, 2010
3
That is the problem, they build the boats around the systems, then somewhere down the road the owner has to get at them for repairs. A talented 7 year old could get in there but then you have child labor laws to worry about. I was thinking of opening up the access hole in the port cockpit hatch so I could maybe get in through there. I'm sure someone else must have had this problem.
Jun 25, 2006
22
-Morgan 323 Port of Everett Marina
I have a 1984 323 and there is a long skinny access port in the quarter birth area. It is a bit tight but I was able to get to the pump. If not that can you install a new one closer to the lazerett?
Dec 27, 2010
3
No way I'll ever get in that opening, and I'm not that big. I think I will have a better chance through the port cockpit hatch. I want to move the pump forward of the engine and replace the hoses.
