Here It Is
Tom, as it turns out, I had this at home. Credit William Berson who posted in August, 1998. He said, "to get super leverage on the mainsheet, replace the 3" blocks (one on boom, one on traveler or arch), with double blocks. Sheet goes over boom block, through arch and back thru boom, back to arch and then to the end of the boom. Sounds complicated, but obvious to setup. Gives enough mechanical advantage so that winch is never needed on mainsheet."I intend to do it. Again, it should resolve your concern about dedicated winch on the starbord side, except when reefing as noted on your other message.Hope this helps.
