David C. Hirtle
I'm looking for a little input from anyone with a 31 O'day (mine is an '86) with the Universal M-18, 14 hp motor. The prop I am currently turning is a 15x7.5x1. This has been been adjusted from a 15x9x1. When I purchased the boat I don't believe the prop was original.I continue to produce smoke @ the top end of the RPM scale. Injectors are fine, transmission is fine, fuel supply is fine. It is not overheating.I would appreciate the dimensions of your prop. Thanks!
