Time to replace some parts and pieces on my 92. Can I find out what Hunter has available...eg hatch lenses, screens, water tank, holding tank, fuel tank?
You can 1. use the Factory Connection on the Hunter Home Page 2. email them at 104341.56@compuserve.com3. call the factory directly at:904.462.3077@The factory web page is at http://www.huntermarine.com
If your 30T was manufactured like mine Hunter installed an aluminum holding tank. My tank developed leaks so am in process of replacing it with a new polyethylene tank. All I have read suggests aluminum is the worst and polyethylene the best for holding tanks. If you are replacing yours I have advice as to how to remove your old tank (difficult since Hunter built the boat around the tank) and suggestions on what to install. I can send pictures and drawings which will help you.
