306 cabin step
Richard
The step on the engin compartment is supported by a wood trim 2x1. It is not strong enough to support a heavy person. The access door to the engin will put pressure on the trim and it will pull away and crack. My dealer installed new trim with two srews on each side to solve this problem. I would bet that the 32,32.6, and 35.6 have the same problem. I weigh 195. Check it out before it breaks!
Scott Narum
326 step
The steps on the 326 are molded into the fiberglass cover for the engine. It has supported me well, and I weigh about the same.
Rob Anderson
Clarify please ....306 0R 326
Are you talking about a 306 OR 326. The heading and body of your post say one then the other. Which model is it that you have had the trouble with ???
Richard
306 Step
Sorry, the 306 has wood steps. The one on the engine compartment is the one to worry about.
