15 amp breaker a must
There are very good suggestions posted here on this topic. BUT PLEASE NOTE: I am looking directly at the instruction sheet for a Leviton(R) GFCI receptacle, quoting it, "A GFCI receptacle does NOT protect against circuit overloads, short circuits, or shocks. For example, you can still be shocked if you touch bare wires while standing on a non-conducting surface, such as a wood floor." In summary, I want to add my vote that it is critical if you are down sizing from the 30 amp power supply to the 15 amp wiring that you add the 15 amp circuit breaker close as possible to the 30 amp supply outlet. Otherwise the smaller gage wiring will be subject to overload during a short. Also, I agree that the GFCI receptacle is needed to protect personnel from a faulty appliance. The GFCI will protect against a ground fault but will not protect against an overload or a shock under certain conditions. I recall that a couple years ago I saw a power supply box at an RV supply store that included a 30 amp plug with a short 30 amp cord to a small weatherproof circuit breaker box (that would stay near the shore power outlet). The box contained a 15 amp circuit breaker and a couple weatherproof 15 amp GFCI outlets. It would need to be evaluated to ensure that it was suitable for marine use.Also, use the electrical outlet tester each time you plug the system into the dock power. This is a little long winded but it is important stuff.
