Rich Wallace
We just completed a two week cruise on our H34 with a 3GMF Yanmar. On the last day we had an experience that needs to be relayed to all owners of the smaller Yanmars. When we are using the diesel for extended periods of time, I try to check it about once an hour to see that is cooling properly and nothing is leaking. On one of my hourly checks I opened the engine cover to the smell of diesel fuel. We immediately shut down the engine and tried to determine the source of the leak.After some investigation it was apparent that the leak was around the fuel filter on the side of the engine. Eventually I found that the threaded aluminum collar that holds the filter cup to the mount had split allowing for a leak between the cup and the mount.Having no replacement parts, we rigged up a funnel and some hose to catch the leaking fuel and were able to motor the last few miles without filling the engine pan with fuel. My suggestion to anyone with the Yanmar 1, 2, and 3 GMF (and I think the 1GM10, 20 and 30's as well) probably need to carry a spare collar along with the extra filters and O rings that you already have. .Happy Sailing!
