Paul - your links
seem to say that a well designed three blade prop will perform better than the "standard" design. My assumption is that prop design is so well known that both propellors have good designs. And I studied prop design long enough to stick with my statement for low speed (2 to 7 knots) props working in water.I have neither experienced nor heard of the vibrations mentioned as both blades are "hiding" at the same time. Threads on this site about propulsion vibrations have all come up with some other cause. In fact, on Lady Lillie, and on any design with a shaft strut, the bottom blade is not obstructed as it rotates through the centerline. Finally, regardless of Admiral's thoughts about dragging a hand in the water, most discussions on this site have conceded a lost half knot or more under sail. That's a big penalty (10% of cruising speed) to pay for minimal advantages.If "conditions on the Thames" means tide and wind, I doubt three blades will help much. If it also includes bucking substantial waves (as we often have on Lake Erie) then the third blade will help in accelerating out of the waves.I'd pay more attention to the Admiral sales pitch for three bladed props if they cited any research to back up their claim.DavidLady Lillie
