Pete
Kevin,(at PYI)could you please tell me the proper size 3 blade (fixed) prop for a Hunter 336.It is appx 11500 lbs in weight and has a 3gm30f Yanmar engine with a 2.62 to 1 gear ratio (not 100% sure of ratio),it now has a 16x13 right hand 2 blade prop,on a 1 inch shaft.The engine is rated at 27 hp max (3600 rpm) and 24 cont. ( appx 2900 rpm). I was thinking about a 15 x13 3 blade. Is this correct or what size would you suggest? Thanks Pete
