F
Frank Bean
I need some advice from other 81' 37 Cutter skippers. I have looked in the archives and I am still a bit confused. I have a Yanmar 30. Is my prop supposed to be a 16 x 14 RH? Is that size both for a 2 and 3 bladed fixed prop? I have a two bladed prop on a 1" shaft. That much I do know. But I didn't measure the prop when I had it out of the water for the hurricane repair work for Katrina. Next. Someone out there who has both a 2 bladed folding and a 3 bladed folding prop I hope will answer my question. Did a folding prop improve the speed of you boat and was the $$$ spent worth the extra speed. Is the folding prop the same size then......16 x 14 RH?Is it then necessary still to have the transmission in reverse if you have a folding prop? I mean does the prop shaft turn at all when it is folded?If someone has had both a two and three bladed folding prop...their feedback would most likely clarify which I would try to talk my wife into.......err First Mate into. Barring a folding prop......what advantge is there for a three over a two bladed....or is there? I am anxiously awaiting.Fair WindsFrankS/V Blue Shark
