2QM20 start-up / update
Richard McDonald
I did get my 2QM20 to start-up successfully Sunday after 6 years of dry dock. Thanks to all that responded with great advice to my previous post. After a lot of cleaning, replacing some of the cooling and exhaust hoses and impeller, cleaning all of the fuel filters, replacing the engine and tranny oils, bleading the fuel system and spraying WD40 in the intake for 15 to 20 revs without compression, she fired up on the 4th try. I ran the engine for 30 minutes starting at low RPM's and working my way slowly up the scale as she warmed up. I used a 5 gallon bucket with a garden hose and drew cooling water from it through the raw water strainer. Oil pressure, charging and water temp were all normal. I stopped the engine after the firts run of 30 minutes and inspected for leaks, etc.. She started back up after the first few revs without any problems. The project is moving along. The mast will be re-stepped this tuesday with newly painted non-skids on the deck. Now on to flushing and re-commisionning the water thanks, installing the new pedestal guard with electronics, wiring, etc.. Hopefully ready to splash in 10 to 14 days!!! Richard 1979 H37C Rhapsodie
E
Ed Schenck
Way to go!
By the book, an excellent example. Those old Yanmars are amazing. I only wish I had some idea of hours on my 2QM20. My 1979 H37C has always been on Lake Erie but I know it has traveled into Huron and Michigan. And I know that one owner towed his dinghy AND his jetski! Yet she runs like a top, always starts on the first crank(since I added the additional solenoid), and even looks new. Now if I could just get 40 horsepower out of those two cylinders. Maybe a turbocharger?
