I'm stuck with resolving my over heating problem. My engine is a 15hp Yanmar (2QM15). I have changed the impeller and thermostat, flushed out the sea water intake from the filter back to the thru hull, cleaned out the sea water filter, cleaned much of the barnacles off my prop and removed most of the carbon build in the exhaust-water discharge mixing elbow. The mixing elbow had a heavy build up of carbon which I was able to remove most which extended the overheating issue from 15 minutes to over an hour and a half. It didn't overheat until I raised the rpm from about 1000 to 1200 which occurred after about 30 minutes. The boat had been motoring at about 4 miles per hour at 1000 rpm and about 5 mph at 1200. The sea water exhaust mix expelling from the boat seems the same as what I note in similar sized engines.
Since the cleaning of the elbow helped considerably, would it be helpful to go the aftermarket version without the elbow and assure best possible flow?
