2GMF Trans Fluid
john jankovic
As I read the Yanmar Service Manual it appears to me that the transmission fluid is the same as the crankcase oil for the 2GM series. Is this correct or am I misinterpreting?
red coles
Correct
Your right,be careful not to overfill,only takes a little. Good luck red
Richard
Trans Oil
John, check the plate on your transmission. I have an '81 2GM which takes ATF, not motor oil. There's a small plate on the back of the trans. that identifies which oil to use.
