Hello All:
Almost have V2947 'emptied' in preparation for winter festivities.
Heaviest job, literally, was today, removing 1-12V and 2-6V batteries
for the cold storage season. Would probably have been easier had the
boat not been on a 'yard' trailer with the gunwales about 8' feet in
the air; anyhow, all done (including my rickety old back which is
done 'in') I'll feel it tomorrow I'm sure.
The question for those with Yanmar 2GM20F's:
The direct distance from the thru-hull to the engine intake, both at
the forward end of the engine, is less than a foot with the engine
intake slightly aft and inboard of the thru-hull.
The current setup has about 18 inches (or less) of hose length from
thru-hull to intake with a very, I say very pronounced, inverted 'U'
shape.
The 'arms' of the inverted 'U' are probably no more that 4 inches
apart; God knows how the installing mechanic bent the hose to make it
fit.
Immediately outboard of the thru-hull (like, maybe 3 inches) is the
wooden 'bulkhead' of the engine compartment; directly forward of the
thru-hull is the removeable '2 step' panel. There is very little room
(inches) above the 'top' of the inverted, 'U' shaped hose. Suffice
to say, she's a tight fit.
Cutting to the chase, this beautiful, almost new Yanmar does not have
a sea-strainer. I'm a little concerned about sucking all manner of
waste into the engine without the benefit of a strainer to cut the
heavy crud (wheat) from the crustacean waste (chaff).
My mechanic 'for now' is not all that familiar with Yanmars and
suggested installing a huge plastic strainer on the engine
compartment bulkead but AFT of the engine and on the side opposite to
the thru-hull/intake. To do so would mean at least 3 feet of hose
from thru-hull to strainer and another 3 feet back to the engine
intake.
If there's one thing the less than detailed Yanmar manuals emphasize
is -"shortest distance possible between thru-hull and engine
intake!". Six feet of hose doesn't sound to me like 'shortest
distance possible'.
I'd appreciate all suggestions, advice, guidance from those who have
done the sea strainer routine with a 2GM20F including strainer
make/model that worked for you in these very confined spaces.
Cheers all,
Geoff Warren
V2947
Powell River, BC
shape.
fit.
intake.
distance possible'.
Cheers all,
Geoff Warren
V2947
Powell River, BC
