My 1989 2GM20F cooling fresh water pump started making noise so I've decided to replace it. I am heading to the boat Friday with the new pump, a gasket, antifreeze, radiator flush, distilled water, a new belt and all new hoses. I've decided to use Prestone Comand Heavy Duty Antifreeze and Prestone Radiator Flush and Cleaner, I've heard bad things about Dexcool. I'm thinking about flushing the system and purging it of all the old green antifreeze before changing out the pump. Does anyone have step by step instructions on purging the system and getting all the air out? Also when installing the new gasket, what type of sealant should I use and should there be sealant on both sides of the gasket?
Any and all assistance would be greatly appreciated!
Thanks!
Thetone
Thanks!
Thetone
