2GM20 Alternator and Starter Wiring
Jun 21, 2019
2
C&C 33mkII Comox
Good Day!
I have new to me C&C33 mII with 2GM 20 and am adding solar with battery upgrade.
I want to run alternator to house bank with ACR to start battery. Solar and AC charger will also run to house.
The current Alt/Starter runs via a single wire to common post on Off-1-All-2 switch.
I would like to run Alt to battery and Starter to switch.
Q1 - is it possible to separate Alt/Start wires and if so, is there anything in particular I should be looking out for?
Q2 - House bank is 2 x AGM G31 220AH total in parallel. Is there any risk with current alternator (sorry do not know the make) charging these new AGM's?
Thanks!
Andy
Welcome @APWTryfan
Andy. Your questions and more are answered in the articles on MaineSail’s site.
https://marinehowto.com/
A search of our forum will yield many threads regarding batteries, alternators, etc. one of our members @Stu Jackson has posted many responses to your general questions. Look for his Electrical 101 links to all you want to know plus some.
We look for pictures of your new boat.
Mar 29, 2017
576
Hunter 30t 9805 littlecreek
Most people disconnect altanator output and tape off then run a new larger gauge directly from post to selector switch
May 20, 2016
3,015
You can move the alt out from common to 1 or 2 which ever is you house. Then read 1,2 or both thread under mussing with Maine sail. That will tell you how to wire the start battery.
Les
These are from my Electrical Systems 101 http://c34.org/bbs/index.php/topic,5977.0.html
If you have TWO SEPARATE WIRES from the C post of the 1-2-B switch to the starter and the alternator, yes, you can do what Les suggests. It's the other end of the same wire as if wiring to the house bank, but it would be better to run directly to the house bank from the AO and don't forget to fuse it at the battery end.
OEM 1-2-B Switch Wiring History http://c34.org/bbs/index.php/topic,4949.msg30101.html#msg30101
Basic Battery Wiring Diagrams This is a very good basic primer for boat system wiring: http://c34.org/bbs/index.php/topic,6604.0.html
This is another very good basic primer for boat system wiring: The 1-2-B Switch by Maine Sail (brings together a lot of what this subject is all about)
http://forums.catalina.sailboatowners.com/showthread.php?t=137615
This is a newer primer for boat system wiring design with a thorough digram: Building a Good Foundation (October 2016)
http://forums.sailboatowners.com/in...dc-electrical-foundation.181929/#post-1332240
The Short Version of the 1-2-B Switch Stuff: http://c34.org/bbs/index.php/topic,5977.msg38552.html#msg38552 This is a link to the Electrical Systems 101 Topic, reply #2
What are ACRs, Combiners & Echo Chargers? (by Maine Sail) [scroll to the top]
http://forums.catalina.sailboatowners.com/showthread.php?p=742417 and http://c34.org/bbs/index.php/topic,9404.msg70131.html#msg70131
Making Sense of Automatic Charging Relays (2019)
https://marinehowto.com/automatic-charging-relays/
You should also be aware of this, especially with AGMS, which may not be your best choice.
Hitachi Alternators 101 http://forums.catalina.sailboatowners.com/showthread.php?t=166123 This comes up so often on other boating forums...
Good luck.
