2GM upgrade
Bruce
My 1992 30T has been plagued with the infamous copper washer scandal since I bought the boat in 96 (otherwise, this is a fantastic vessel) I have lived with the fuel aroma, and have almost come to like it. But, at the New England Boat Show, the regional Yanmar distributor had several of their engines on display. I found out that the newer 2GM's have a revised fuel distribution system eliminating the wretched washers. The chief mechanic said retrofit was not a particularly difficult chore, so it will be done...FYI
K
Ken
What is the 2gm problem?
What is the copper washer fuel system problem on the Yanmar? My 89 Hunter has the same fuel smell, and I'd like to know how to fix it.
Steve O.
copper washer
The problem is that once you open the bleeder screw once or twice, the copper washer gets squashed and loses its seal. Solution is to replace every time you bleed. Last time I replaced I was given a plastic washer and it seems to be working OK.
Bruce
Steve
The retrofit kit for the 2GM basically replaces all the aluminum tubing and washers with fuel hose and clamps, so I am told...
