2gm reduction gear oil seal????
Dan Geltmacher
I have a leak somewhere back around the reduction gear. I know it's transmission oil cause it's clean. I think the culprit is the oil seal on the shaft. Has anyone ever taken on this job on an H30? I think the shaft has to be pulled which means the rudder. Any ideas? Open to them all! I do all my own mech work but... Dan
L
LDV
oil leak
Dan, I recently over filled my transmission, and it leaked out. Needless to say I was alarmed to find clean oil in the motor bilge. It turns out that the filler cap is also a vent. Unfortunately the gear shifter is on the other side of the filler, so I'm not sure that this may also be your problem. Ludy
Joe
Did it on my 2gm/ 80H-27
It can happen if the nut on the outside of the flange coupler gets loose. You don't have to pull the boat or remove the shaft to get at it. First,measure the hight of the shaft from the hull.Then, remove the 4 nuts and bolts which hold the two flanges of the coupler together. Then push back the shaft through the log. Tie up or block the shaft so it stays at the same height it was at before you started so that it doesn't droop. The nut is on the back side of the trans coupler. If it's lose snug it up. Usually, it will only leak wher running. If you're certain the seal is bad, remove the transmition by removing the bolts around the trans bell which attaches it to the engine.You will have to disconect the shift cable from the shift arm and possibly unplug the wiring harness at the engine to get it out. I followed this process and sent the trans to Mack Boring in Union NJ. (I needed new cones too). It's easy to reinstall the trans and reattach the coupler. WARNING...have the engine and shaft realigned before running. If you take your time you can do it your self. Or... you can have the yard do it. Get a price ..it may be worth it.
Dan Geltmacher
NOT REDUCTION GEAR?
JOE, THANKS FOR THE ADVISE. I FINIALLY WHERE THE OIL IS COMING FROM. THE OIL SEAL ON THE SHIFTER HOUSING IS LEAKING. I'M NOT SURE IF I CAN PULL THAT OR NOT. IT DOESN'T LOOK TO TUFF, BUT NOT SURE IF/WHEN I PULL THE SHIFTER SHAFT WILL I HAVE A HARD TIME RETURNING IT. DAN
Joe
Try...you can always remove the trans
I'd call Mack Boring. The'll be glad to offer tech advise. If you can remove it , you'll save time and money. If not, you can always remove the trans as I suggested. Let me know how you make out. Joe.
