Mark Smith
I own a 2gmf Yanmar, and I also own a 1-2-3-gm yanmar service manual. My problem is that the 2gm cooling system in the manual is not the same as the motor I own. They clearly show the cooling system with the raw water pump (running off a belt) but what they dont show is what I have a (leaking) behind a second and unshown (pump) running off the belt on the top front of the motor. The motor is freshwater cooled, is this the problem? I need to know how to get gaskets for the top pump (that does not exist) as any Yanmar owner should know I need at the very least a explanation of what I need. I am assuming that it would have to be a fresh water pump, but I need part #s, or an explanation. Thanks,Mark M Smith
