Does the bilge in a 299 drain through a fitting on the galley sink drain? Mine appears to have originaly been set up that way, however the wiring to the bilge pump is run to the 2nd bilge compartment thru a pvc tube, while the only exit for the drain tubing is located in the 1st bilge compartment. Anyone know the correct way to rebuild this before I cut extra holes? Thanks,,
