29.5 Winterizing Water
Joan
Since the fittings on the hot and cold water are PVC (assume they screw off),what are you using to connect those lines? Do you disconnect the strainer before the water pump and insert the pink stuff there? Another 29.5 question: Is the tack on the main sail a D ring? In high winds this managed to come loose and land in the sea.
Peggie Hall/Head Mistress
Read "Winterizing Plumbing" in the...
Head Mistress forum Reference Library (on the right side of the forum homepage)...it gives complete instructions for wintering both the fresh water system and the sanitation system.
