29.5 Portlight screens
jcela
Jul 7, 2004
20
Hunter 29.5 Kemah
Does anyone knows the brand and model of the large portlights used on 1995 29.5 Hunter? I need to change the screens because the frames are bend and I cannot find a brand name or model on the portlights. Thank you
Hunter 336 Lake Champlain, NY
I suppose you are talking about the large opening ports on the cabin top. Contact Hunter and they will sell them to you. If I remember, they cost around $65 a piece. That's what I have done for our 1995 336 model and the new ones fit perfectly.
Good luck.
jcela
Jul 7, 2004
20
Hunter 29.5 Kemah
Tribu336 thank you for your suggestion but I'm looking for the screens for the port lights on each side of the boat, one inside the head and the other on top of the stove. The outer dimension of the plastic frame of the screen is 14-3/4" x 6-3/4". It has a 1" radius on each corner and the color is black. Anyone?
Thank you
Jun 2, 2010
10
Hunter 29.5 Bellingham, WA
They sell them here on hunterowners.com which I replaced the ones on my 29.5 with. I believe this is the larger ports you are giving measurements for-- Gray Ports 715 size fit mine perfectly ~$20 apiece.
Good luck!
