The 29.5 uses circut breakers instead of fuses . The switches at your master panel are circut breakers . The rating should be marked on each switch . You also have master breaker in the starboard cockpit after locker next to the battery switch . Your radio ( VHF ) may also have an in line fuse at the radio . john
