Need help out there, My 29.5 bilge pump stopped working.Found out the hard way.Water almost up to the floor boards. I put in a new pump, new float, and still the thing wont work. Any ideas-thanks rob.
you have 12 volts first at the switch, then at the motor. If no juice, then check for an inline fuse that might need replacing. Trace the circuit back to the source until you get 12 volts.Terry
Robert, I had a 1995 29.5 and there were a couple of circuit breakers mounted on the battery switch in the aft starboard cockpit locker. I know one was an A.C. breaker and I think there was another one for the bilge circuit. I can't remember for sure, but it would be worth takeing a look there. Good luck. Gotta have a pump. ken
