Water burps out of the exhaust but does not flow regularly out on a continuous flow (blurp of water every few seconds...maybe a cups worth). Boat does NOT overheat, impellor, seals, bearings and shaft recently changed by a marine tech.I assume from the diagrams, this does not have a raw water exchanger to clean, correct?Is this normal and/or is there something I should be cleaning?The boat is no longer at that marina and is 200 miles way from the marina.
