272 mast sheaves
Jan 8, 2009
33
Oday 272 Monmouth Boat Club Red Bank NJ
Would anyone know where I could purchase the plastic sheaves that are at the bottom of the mast.
Charlie D
Aug 3, 2012
2,542
Sheaves are measured by diameter and width to handle a certain size line: 5/16, 3/8, 1/2, etc. You can probably source them in numerous locations; however, rig-rite / Zspar might have them, as they have the molds for the tabernacle and step plate. On the other hand, they have had those two parts on backorder for the 272 for something like 7 years if I recall a recent conversation with them correctly, so I don't know if they would have any of the other parts on hand.
Thanks,
Andrew
Nov 1, 2010
100
Oday 272 Brownstown, MI - Lake Erie Metro Park Marina
Charlie D, I also am thinking to change 3 or 4 of my mast base sheave wheels while on the hard this winter. On the 272 O'Day do you just drive the axle out with a punch? Or is there a special technique to perform the task?
Regards, John
Pat
Jun 7, 2004
1,250
order two for me too.....mine are going to cause a real problem soon...here's wishing
a Merry Christmas to everyone on this web site! Pat
Jan 8, 2009
33
Happy and Pat
I believe you need to drill out the outer pressed on shaft for removal then insert a something to keep the Sheave in place. If you look at the shaft it is smaller then the sheaves that you can buy from shaffer or some of the other rigging companies. they appear to be about 2 inches round for I believe 3/8 line.
Charlie D
Jun 14, 2012
23
oday 272LE Lake Petenwell
Been there, done that, two 272's, not a big deal. The pins all punch out, some have to come out in order so you punch through one to get at the next. As someone else stated, almost every rigging mfgr sells them.Just measure accurately and be sure you're SAE or metric. Have a good winter!
Jan 8, 2009
33
Thanks captain, I did not think about the SAE or Metric thing.
