Justin
I fully pull my trailer into the water but the 26x just won't go all the way onto the trailer. It is afloat in the stern when I load and not heavily loaded. The ballast is usually full. Trying to remove that by motoring would be a real bother when I almost sail in to dock. I then have to hit the brakes hard to get it forward enough when the ballast has drained. What's up with this, design flaw. The only added weight in the bow is maybe a 1/2 full water tank and twin batterys right a-bow of the front dinete seat.Hate slambing the brakes to get it loaded safely and the crank/pully won't move that much weight. It is cranked as far forward as possible before I remove it from the water. So what else can I try.
