at the end of the season I sailed for two days to get to Hampton. Downwind sailing was horrible. When I got to the marina I went to pull the keel up and the cable was slack . I think the keel was stuck up, caught in marine growth in the trunk. When I trailered it, I don't know if it was up or down and swung up or what.
When I pulled the trailer up the ramp the cable was dragging. It was no longer connected.
Well I have had a busy spring but before I splash the boat I need to fix this. This is the unweighted swing keel. Is there any ways to get that keel down enough on the trailer enough to see and fix it?
What kind of simple rig do you guys use to get the trailer out if I need to do this? I can remove the keel support but the axle is going to be in the way and I think the front bunk too. If the keel support was removed, could I remove the keel and see what's going on at the connection point?
