26M Info
A
Alex
I spoke to a dealer in California today and he relayed the following Says the M does not have any fixed ballast. If anyone knows different let me know. I read in one place that the added ballast (300Lbs) is bult into the DaggerBoard well. The DaggerBoard is raised/Lowered via a line to the cockpit. This is in keeping with no ballast in the board or ballast built into the well because a heavy board would require somr fancy gearing system or electrical means of manipulation Vessel Weight..........................2500 Lbs Trailor Weight......................... 780 Lbs 70 HP Suzuki Weight.................... 335 Lbs Total..................................3615 Lbs The reason for the Suzuki as opposed to the HOnda is that the Honda (although quieter) is not fuel injected as is the Suzuki. Also the Suzuki Powerhead is slimmer allowing for easier access to the vessel via transom boarding They've only sold 4 boats to date The L.O.A. is still 25'10" The salon table may be connected to a secondary connector in front of the Helm station Post for use as a cockpit table He owns a boat with a liner and thinks the material lining the M is similar and is/will be a moisture wicker/mildew problem. Says from his experience you will need some sort of Desicant or Dehumidifier to prevent problems Vessel said to do about 20 MPH with the 70 (No ballast) Vessel said to do about 18 MPH with the 70 (Ballasted.) There is now Flotation in the Mast as well The factory will continue making both. The X as a daysailor for folks more concerned about price and the M as the more solid of the two for folks more concerned about performance. (If they are going to continue making the X then there may still be room for improvement to it)
Dennis
No more 26X
There is no fixed ballast per se, except there is on the bottom of the hull the weight of additional fiberglass (as you pointed out)--- don't remember exact weight but I believe it is about 300 lbs. I spoke with Bill at MacGregor, as well as, my local dealer and the 26X is no longer in production. The 26M is the only choice going forward. As to access from the transom, I don't care what you put on, the only way to allow access now is to eliminate the engine all together.
