Hunter throttle and shift cablesAnd now a word from the sponsor...
H260 helpful hint #38... Loosen (a bunch) the water ballast tank valve after loading onto the trailer but before pulling the boat from the water. The weight of the water on the valve will make loosening the wingnut impossible if you don’t.Thanks all good ideas and we will be trailering in and out of water with mast up so we will not be slipped
+1If you have any other questions just ask. Make sure tire pressure is checked regularly
