I have a 26 1994 with the original trailer that I am going to pick up in western kentucky....does anyone know the rim size for the wheels? I'd like to pick up a spare tire before I trailer it home..thanks
I bought a spare rim from a local trailer supply house size:14"X5" with 5 hole 4.5" lug patternAssuming all the trailers had the same axles, mine is a '98 Yacht Club trailer that came with my H26. I put a 205-75R14 tire on it which is the same size as the OEM on the trailer.Hope this helps.Jim Covey
I suggest you find out exactly what size tires and wheels are on the trailer you are buying. Different manufacturers made trailers for Hunter. I got a spare with my '94 H26 from the dealer and it was a different size than what was on the trailer. I found this out well after the fact when I needed it. It would also save some potential headaches if you had the wheel bearings checked and the tires balanced - makes the rig roll a lot more smoothly.Good luck.
