Hi folks. Today I purchased a Hunter 25.5 which to my un-trained eye looks to be in decent shape (very dry everywhere I looked).
However on our maiden voyage the Mercury 5hp (2 cycle) died. I think it is over-heating and shutting off; we noticed there was no stream of water shooting from the back bottom of the engine. Does this usually indicate the impeller is broken?
What are your thoughts on repairing vs replacing with a used engine (maybe slightly more HP)? I'm in a lake (so there are no currents, etc.).
Also, should I be looking at "long shaft" engines only, or will "short-shaft" engines work?
Thanks!
Thanks!
