240 rudder line/control ineffective!
Bill Welsch
The factory installed system on our 240 that is designed to keep the rudder in the down position is really lousy. The line gets stuck in the clamcleat and it is IMPOSSIBlE to dislodge it! We recently had to unscrew the clam cleat to release the darn thing. Has anyone attempted a refit on this system? I assume it is similar on the 23.5 although I'm not sure. Thoughts and input welcome. Thanks in advance Bill Welsch "Renewal"
Dave
rudder
Yes the 23.5 is like this but a longer line helped!! But I never liked to lock it down, just use the "wing nut" this will let it kick up if you, like me , hit something Good luck Dave B.
Mark Kissel
Spinlock...
makes a PX Powercleat clutch that will release the line with a gentle upward tug under severe load. It works great! Mark Kissel s/v Kittiwake H240
Brian Kile
releasing clam
Problem with the 240 factory design is if you tighten the pivot nut too much(not a wingnut either - mine came with a wrench nut!), it doesn't set easily(without your foot assist), too loose and rudder rides up under sail. APS (http://apsltd.com/default.htm) carries a strain-releasing clam for <$20. After much thought over best way to redesign, I plan to get this clam to simply replace the factory one. This way u can keep the rudder pivot nut a bit 'loose' for easy up/down and still have kickup safety feature. If line 'lodges' itself, you can kick it up manually to dislodge it. I had a similar kickup cleat on my Nacra cat and after a few bottom drags, noted quickly that the 240 needed same. kile 'What the Heel'
