Factory trailer problems
My H240 came with the factory trailer, which at the time was Magic Tilt. It looks good, is galvanized, and has features like a ladder in front and a tongue extension. But there are substantial problems with the factory trailer:1) The GVWR for the trailer is for an empty boat - no gear or outboard, and no margin whatsoever.2) The tongue extension bends when you use it and you have to reverse bend it to get it back in place. The only time I used it I had to jump on it and use a car jack to straighten it out.3) The bunks are not high enough and too much weight is on the centerboard, causing cracks in either the support lumber, the boat's fiberglass, or both.4) Customer service dept. apparently doesn't exist.Call Hunter for a barely adequate solution, it that is acceptable to you.
