Neil
I researched the topic thoroughly a couple of months ago in case I could only find a F235 without a trailer.The 'best' (value, features, etc) F235-customized trailer I could find was from Roadmaster (see web page roadmaster.com). I don't know if you can buy direct from them, or if they will get you to go through an agent.However, a big part of the cost of these things is getting it from the factory to your location. If you can pick up from the factory, it's a huge savings - especially if it's not in your home state as you can then probably avoid sales tax in the factory's State.Roadmaster is close to where i live. there were also reasonably priced trailers customized for F235s in the midwest area, and one in/near Toronto. Tirad seem to be the gold standard, but they are also by far the most expensive.By the way, I'd strongly advice getting a galvanized trailer - sosts a bit more in the beginning, but saves a huge amount of maintenance later.Good luck.
